That's an offensive cost to the environment. Future archaeologists will be able to identify a "Vista Upgrade Layer" when they go through our landfill sites.'"
The sad part is thats probably true. However a lot of people do recycle machines, theres a company in the hills that takes old pcs (pentium 3s etc) fixes them up so they can get on the internet and do word processing and sells them for next to nothing. A P3 is really all you need to do 80% of office tasks.
Edited by Rolls
the UK Green Party are a bunch of uneducated freaks .... what DRM has to do with anything whatsoever is beyond me .... and the claim of people dumping old monitors - this has nothing whatsoever to do with Vista lol
hi man,
AVG is good Spybot is good
personally i used Active Virus Sheild from AOL and kapersky
http://www.cpuid.com/cpuz.php that will tell you all sorts of good information about your pc including how many ram slots you have
forget about upgrading your laptop, period. They are notoriously temperamental, and you will require specific model and spec ram chips from the supplier that built the laptop - and these are normally 200% - 300% the price of generic PC ram.
hey guys, how can i find out how many RAM slots i have in my laptop?
also, what do people think of AVG anti virus, Spybot and Sygate firewall????
I used all 3 for ages, and think they are great as they are free to use and catch 99% of stuff.
Currently though ive switched to Bitdefender as i thought avg was letting something through...
Bitdefender was my choice amongst the highest rated ones as it has the option to scan fast like AVG, or do a full or deep scan like Kaspersky, NOD32 etc...
It also has an included firewall, spyware and malware package in the 1 program. Saves me updating the 3 programs u listed, then scanning each.
ATM i cant be farked figuring out why vista wont run on my pc. Memtest has no errors, and nothing is oc'd.
I think it must be the way ive got my hdd and dvds setup...
DVDr is pri ide drive
DVDrom is the Pri. ide secondary
Raptor (boot drive) is in sata2 -port 1
Seagate (storage) is in the sata2 - port 1
I think vista cracks a shit if it aint on an ide slot....need to keep researching....
for now im having fun, as ive got Ubuntu dual booting with XP. Planning on seeing how Beryl goes, and what else i can get going on linux...
I have Vista running an a SATA drive no problems.
I would definitely not run your DVD burner on a primary IDE port - put the Burner as Secondary master, and the DVDROM Secondary slave.
i forgot to mention before Active Virus Sheild is FREE also
http://www.activevirusshield.com/antivirus/freeav/index.adp?
*Powered by Kaspersky Lab, one of the largest anti-virus providers, worldwide.
Edited by Madaz
isnt it better to run each on a separate ide port, not master/slave on the 1 ide slot?
Any difference to read write times when copying / writing from a disc to another?
black32 - I have always run DVD/CDRoms and Burners on the same ide ribbon and don't notice any speed issues - I have always done it this way. The read/write speed of the drives themselves is by far the limiting factor.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
