That's an offensive cost to the environment. Future archaeologists will be able to identify a "Vista Upgrade Layer" when they go through our landfill sites.'"
The sad part is thats probably true. However a lot of people do recycle machines, theres a company in the hills that takes old pcs (pentium 3s etc) fixes them up so they can get on the internet and do word processing and sells them for next to nothing. A P3 is really all you need to do 80% of office tasks.
Edited by Rolls
the UK Green Party are a bunch of uneducated freaks .... what DRM has to do with anything whatsoever is beyond me .... and the claim of people dumping old monitors - this has nothing whatsoever to do with Vista lol
hi man,
AVG is good Spybot is good
personally i used Active Virus Sheild from AOL and kapersky
http://www.cpuid.com/cpuz.php that will tell you all sorts of good information about your pc including how many ram slots you have
forget about upgrading your laptop, period. They are notoriously temperamental, and you will require specific model and spec ram chips from the supplier that built the laptop - and these are normally 200% - 300% the price of generic PC ram.
hey guys, how can i find out how many RAM slots i have in my laptop?
also, what do people think of AVG anti virus, Spybot and Sygate firewall????
I used all 3 for ages, and think they are great as they are free to use and catch 99% of stuff.
Currently though ive switched to Bitdefender as i thought avg was letting something through...
Bitdefender was my choice amongst the highest rated ones as it has the option to scan fast like AVG, or do a full or deep scan like Kaspersky, NOD32 etc...
It also has an included firewall, spyware and malware package in the 1 program. Saves me updating the 3 programs u listed, then scanning each.
ATM i cant be farked figuring out why vista wont run on my pc. Memtest has no errors, and nothing is oc'd.
I think it must be the way ive got my hdd and dvds setup...
DVDr is pri ide drive
DVDrom is the Pri. ide secondary
Raptor (boot drive) is in sata2 -port 1
Seagate (storage) is in the sata2 - port 1
I think vista cracks a shit if it aint on an ide slot....need to keep researching....
for now im having fun, as ive got Ubuntu dual booting with XP. Planning on seeing how Beryl goes, and what else i can get going on linux...
I have Vista running an a SATA drive no problems.
I would definitely not run your DVD burner on a primary IDE port - put the Burner as Secondary master, and the DVDROM Secondary slave.
i forgot to mention before Active Virus Sheild is FREE also
http://www.activevirusshield.com/antivirus/freeav/index.adp?
*Powered by Kaspersky Lab, one of the largest anti-virus providers, worldwide.
Edited by Madaz
isnt it better to run each on a separate ide port, not master/slave on the 1 ide slot?
Any difference to read write times when copying / writing from a disc to another?
black32 - I have always run DVD/CDRoms and Burners on the same ide ribbon and don't notice any speed issues - I have always done it this way. The read/write speed of the drives themselves is by far the limiting factor.
    • Hi All,    I have my BW EFR 8474 with a T4 split 1.05 rear housing. Rear housing is ceramic coated and drilled and tapped for EMAP take off.  Supported 520awkw at 35psi through the 8HP with ~5k rpm spare on the BW 127k limit. Ran a 9.98.    Turbo is one of the first that was released but only done ~3k kms.    Asking $2800 happy to negotiate. Only selling to upgrade.   Located Gladstone QLD happy to ship.
    • Hi is the Toshiba sceeen still available?
    • Just wondering how come the hood was grinded down?
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is 2050 rpm, going to WOT sees the MAP go +ve very quickly and it has >5 psi by the time it hits 90 km/h. That's still <2.5k rpm, so I think it's actually doing really well. (I edited this from a previous version where I stated 80km/h was <2000, but that was a false memory. If I am rolling at ~1700 in 5th and floor it, it will start making boost before it goes over 2k - which is a separate "experiment" leading to the same conclusion. Which is that the boost threshold is actually quite low. It's not fast there, obviously, but it certainly makes progress towards going fast, which is not what it's been like for a long while!!) Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
