That's an offensive cost to the environment. Future archaeologists will be able to identify a "Vista Upgrade Layer" when they go through our landfill sites.'"
The sad part is thats probably true. However a lot of people do recycle machines, theres a company in the hills that takes old pcs (pentium 3s etc) fixes them up so they can get on the internet and do word processing and sells them for next to nothing. A P3 is really all you need to do 80% of office tasks.
Edited by Rolls
the UK Green Party are a bunch of uneducated freaks .... what DRM has to do with anything whatsoever is beyond me .... and the claim of people dumping old monitors - this has nothing whatsoever to do with Vista lol
hi man,
AVG is good Spybot is good
personally i used Active Virus Sheild from AOL and kapersky
http://www.cpuid.com/cpuz.php that will tell you all sorts of good information about your pc including how many ram slots you have
forget about upgrading your laptop, period. They are notoriously temperamental, and you will require specific model and spec ram chips from the supplier that built the laptop - and these are normally 200% - 300% the price of generic PC ram.
hey guys, how can i find out how many RAM slots i have in my laptop?
also, what do people think of AVG anti virus, Spybot and Sygate firewall????
I used all 3 for ages, and think they are great as they are free to use and catch 99% of stuff.
Currently though ive switched to Bitdefender as i thought avg was letting something through...
Bitdefender was my choice amongst the highest rated ones as it has the option to scan fast like AVG, or do a full or deep scan like Kaspersky, NOD32 etc...
It also has an included firewall, spyware and malware package in the 1 program. Saves me updating the 3 programs u listed, then scanning each.
ATM i cant be farked figuring out why vista wont run on my pc. Memtest has no errors, and nothing is oc'd.
I think it must be the way ive got my hdd and dvds setup...
DVDr is pri ide drive
DVDrom is the Pri. ide secondary
Raptor (boot drive) is in sata2 -port 1
Seagate (storage) is in the sata2 - port 1
I think vista cracks a shit if it aint on an ide slot....need to keep researching....
for now im having fun, as ive got Ubuntu dual booting with XP. Planning on seeing how Beryl goes, and what else i can get going on linux...
I have Vista running an a SATA drive no problems.
I would definitely not run your DVD burner on a primary IDE port - put the Burner as Secondary master, and the DVDROM Secondary slave.
i forgot to mention before Active Virus Sheild is FREE also
http://www.activevirusshield.com/antivirus/freeav/index.adp?
*Powered by Kaspersky Lab, one of the largest anti-virus providers, worldwide.
Edited by Madaz
isnt it better to run each on a separate ide port, not master/slave on the 1 ide slot?
Any difference to read write times when copying / writing from a disc to another?
black32 - I have always run DVD/CDRoms and Burners on the same ide ribbon and don't notice any speed issues - I have always done it this way. The read/write speed of the drives themselves is by far the limiting factor.
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
