what does this say in some sort of english guys, is what i have good?
thanks fello freekazoids
go to the SPD tab in CPUz and in there it will show how slot and # however many slots show up when u click it is how many slots you have
but in the screenshot you posted it says DUAL that means your current ram is running in dual channel so theoretically you could run 4gb in the 2 slots that you have asuming theres no more slots
All it means is you r ram is running dual channel ie. your laptop has 2 identical ram chips running in serial or dual channel mode. Chances are your laptop only has 2 ram slots and both are already full.
I don't know where his overclocking comment comes from - your laptop is not being overclocked.
FYI when you overclock a PC you make it faster. So by upping the fsb,the clock speed rises, and your pc goes faster. Like I am running my X2 4200+ system (which clocks at 2.2Ghz) at 3Ghz, which effectively makes my PC a X2 5800+ .... healthy speed increase for no $$$. Downside is the harder you clock a CPU and ram, the hotter they get, and it supposedly shortens their life expectancy. If you want to know more Wikipedia or Google are your friends. You will find literally thousands of articles and websites dedicated to this.
thanks alot, that helped. it says i have 2 slots, with 512mb things in each one. if that makes sene. i know lappies have come along way these days in the way of cooling etc...but is it not a good idea to up my ram to say 2 x 1gb ram sticks...will that cook it? any idea's to help my lappy from not cooking? thanks
upping your amount of memory won't affect your laptop negatively in any way. Since you are not overclocking you don't have to worry about heat etc.
But, you will find the price of 2 x 1Gb ram sticks to suit your laptop brand and model to be OUTRAGEOUSLY expensive!
either its just me or i got heaps of spyware or something but id expect this lappy, 2ghz, 1gb ram 2 x 60gb hard drives to go pretty well....it feels like its lagging behind a bit. just with some things....is it possible to pretty much wipe the hard drive, keeping all my stuff on the hd i dont use and then starting again..to get rid of any spyware etc.... sorry bout all the questions but i use this lappy everyday and its givin me the shites. or is it better to put all my shit onto an external hd and taking it back to where i got it? im just a tight arse lol
forget about upgrading your laptop, period. They are notoriously temperamental, and you will require specific model and spec ram chips from the supplier that built the laptop - and these are normally 200% - 300% the price of generic PC ram.
Its not that bad, I sold laptops as my full time job for a year a few years ago and as long as you use the same sticks its fine. Its only older laptops when using new high density 512mb pc133 sticks that they have trouble.
Just get a matched pair and you should have no worries.
Back up your personal shite on CD/DVD/or external HDD, then run the recovery CD the lappie came with. They pretty much run themselves - should format your HDD (all data will be lost if not backed up) and install Windows and all the oem programs.
If you're not comfortable doing it I suggest you take it back to where you bought it, or drop it to me overnight and I will do it for say $50 cash. I am in Northgate - not too far from you I believe.
DO NOT overclock a laptop. they have only 1 fan at best and little or NO efficient ventilation. might aswell throw it in the bin, along with 2000 dollars for buying a new one.
At worst they will overheat and become unstable, slightly increased temps barely reduce the lifespan of the chips, its running higher voltages that does. Get a proper temp monitoring program and keep it within 65c on load and you'll be fine. Even if it did kill the chip you wouldn't be up for a whole new laptop.
Edited by Rolls
who cares when inexperience can lead to permanent damage. random rebooting even on new installations, undesired effects man... its all a conspiracy.
Geez you could say that about anything, even winding up the boost on your car.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
