I can model and put cars in GTR2 and Rfactor
I worked on these
http://www.rfactorcentral.com/detail.cfm?I...rdo%20Challenge
i started the model before our "head" modeler made the final product
i had made a 33GTR JGTC to go ingame but due to commercial work i stopped
Oh...so u have time to start modeling and no time to organize a cruise... :woot:
hahaha you got pwned :D
goto modeling sites pauly they tell you the best program to use
and no its no cad i cant be bothered looking it up cause this pc takes like 30 secs to load a webpage due to 4mb gfx card
How dare you! APO BISSO STAITHLO GAMOTO CATZACADO ELLA RE!.
Im Napolitan you sangiovese.
wog is greek and italian... at least as far as I understand any olive skinned european kid. = me too its ok buddy.
Edited by Pauly33GTS-t
