I think you're still looking around the 1100 - 1300 dollar mark.
I get the feeling though that some time in the future sony may release a fully software emulation of the ps2 hardware for ps3. And then you won't need to get a 60gig. Thats just a bit of an eduated guess.
so its true you cant play ps2 games on a 40gb ps3 :rofl: i thought that sounded fishy but hey we are talking about sony
i got a feeling a chip is on the way letting u play copied/downloaded games as well as PS2 games...maybe more :yes:
query:
Q6600 @ 3.60 ghz (2.4 stock) G0 stepping model
2900xt (two-off) with coolermaster glacier-600 water cooling
thermaltake bigwater 735
70degrees core 0, 69 core 1, 67 core 2, 66 core 3
on full load
is that too hot?
bearing in mind the graphics cards idle at 49degrees
runs at 47-44deg on idle
pump - cpu - pcie - pcie - radiator - reservoir - pump
had a nth bridge water block as well, but not on atm
might have to refit it along with the double radiator - just that the extra radiator has to sit outside the case :)
Yeah man that is WAY too hot for a water cooling system. I would turn your voltage down a tad - but you may have to lower your fsb too. What voltage are you currently running? I would think around 3.8v, which is probably too hot. Your CPU won't have too longer life at that rate. 44 degrees is way too hot at idle too.
Should not even be that hot with a really good heatsink and fan.
Put more case fans in and get more air flow will cool it down heaps. I have 2 x intake and 2 x outlet fans, plus the CPU, VGA card and dual PSU fans. There is no such things as too much air movement. Is the fan working properly on your radiator? I think it may not be - that would be your problem.
yeah thought so
better rejig it and add the external double radiator/fan system (its a 745 system, but only setup the small single radiator)
the 2900xt's used to see 100degrees on air (stock) on load, so the water has brought them down by 35degrees
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
    • This is a stupid reason to get a car. I thought someone mentioned something about not trying to be pretentious... Flexing is same same, you just think you're cool doing it.
