They arent all my times, only the 1.00.777 is mine. The others are from other people who have posted their times in this thread. Yeah and all tyres are on sports soft. Im still having trouble beating the 1.00.298. thats an awesome time, will need a perfect lap for that. Give it a go!
u should display the times as above... like SMR33 did.
e.g.,
Vehicle: R34 GTR (not v-spec, just the basic GTR)
Weight: 1540kgs
Power: 244kw
Tyres: Sports Soft (S3)
Transmission: Manual
Controller Type: GT4 Steering Wheel
Details: Vehicle was straight from Nissan in Arcade Mode (I ran the Time Trial in Arcade Mode)
Time: 1'01:813
are they all using S3 tyres?
almost 1min flat is a good time.. gonna be a good challenge :woot:
  • Replies 73
stock r34 challenge so far top 4 times to beat :)
1. 1.00.298
2. 1.00.777
3. 1.01.813
4. 1.02.677
Keep em comin! :)
Weight: 1540kgs
Power: 244kw
Controller Type: Standard Dual Shock controller
Time: 1:00.137
yay! puts me on the top i think :ban:
OK, gave it another crack tonight:
Weight: 1540kgs
Power: 244kw
Time: 0:59.956
Weight: 1540kgs
Power: 244kw
Time: 0:59.956
:yes:
holy shit!
  • 3 weeks later...
Weight: 1540kgs
Power: 244kw
Time: 0:59.956
:P
:) nice time!
have to give this another go on the weekend. I have to find over 3 tenths!
will give the Mines GTR on race-qual tyres a go too
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
