Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Well Bel... Sounds all too familiar.
I had a ****ed up life at school. Especially year 12. My two best friends turned around and started calling me a fat whore.. and I never went anywhere anymore cause I was too fat.
That really ****ed me up. My confidence didn't exist.. I was soo down my immune system was none existant. I got sick at the drop of a hat. I put on 20 kilos in 5 months and never went to school.
My marks picked up cause my teachers helped me cause they knew what was going on. I didn't do well in high school and I now wish that i had just ignored them and got on with it.
But whats done is done.
I think most of my low self esteem stems from this. My two (what I thought) best friends ****ed me up.
Guest 87vlt
Originally posted by BelGarion
87vlt i went to a coed school, i came out pretty ****ed up, i got a shocking self esteem i hate myself, im terrified of girls after the ridicule i used to get at school.
dude just to let you know anyone who saw what I was like up until about 18 months ago would be able to tell you what kind of a mess I was in. If it wasn't for my mates, my mum, councilling and my Doctor I wouldn't be here today. I have been much further into depression than anyone of you can imagine. Boarding school wrecked my life. I hate gay people, lesbians included, I hate ****ly people, I have a problem with typical australias (ie eat steak, meat pies and drive v8s). I now have a very short temper and will go off my nut over the smallest things. and yet wehn I was at school I just stood back and took all the crap from the **** wits at school and kept quiet. Now i'm out of school If I see people I went to school with that pissed me off I go out of my way to make their life hard. It also now helps that I've grown 2 inches and put on about 30 kg :)
I don't think i talk to anyone from school anymore.
I was always taht little bit more mature than all of them and I didn't like anything they wanted to do. Like go to the movies and perv on the guys...
I'd rather go out all night cruising down the coast or go to willowbank with my dad than go out with them.
I've found a hell of a lot nicer friends now... They appreciate you for who you are... Not stereotype you against people at school
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
