Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
i am agaisnt them hiding in the pack and lettin em race, thats wrong, what ever happened to prevention being better than the cure, the cure is to build a dragstrip complex on the goldcoast, the prevention is to stick patrol cars on the m1 (marked ones that is) and speed cameras along the m1 and that will stop it, but it still wont solve the problem
Originally posted by BelGarion
chaos those rules have been in for 6 months or so now,
that magna aint that hardcore, i certainly dont think its supercharged, id be surprised if it was
it is modified to keep up with the other cars
a stock magna wouldnt have a chance
there is cameras
but theres more unmarked cop cars though than the marked ones
dont see many of them on the m1
but you are right instead of hiding they need to be seen
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
