Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest Boxhead
nah i wear glasses, its a long story, but basically the day my father killed himself he broke a window(smashed it) infront of me, a day or 2 later i found a tiny bit of glass i rekon it could have to do with it.. but i dont mind.. makes no diff to me... if people dont like the way i look then its there problem,
well anyway im off now
nite bel and boxy
remember bel if she doesnt like u cause of ur looks shes shallow ok
but dont be affraid to get to know her more and dont be upset from rejection it always happins to everyone its life mate
and boxy....
u keep being u :D
and learn to drive manual its not hard my little brother can do it sorta
nite u lot
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
