Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest 87vlt
Originally posted by Boxhead
sorry to hear that chaos, did the fact your gay have anything to do with it.. :D only kidding...
matt, im off to watch zoolander.. but if ya need to chat  im here, and i like your car...
thanks dude ... I like my car too and I'm not parting with it to please everyone else ....
Guest 87vlt
its cool mate... i know what its like for everyone to not like you.. or somethin you do, i guess thats why im a bit punk.. **** them i say, be yourself.. and do shit coz you want!!!
I've been called a punk too amongst other things .....
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
