Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Originally posted by neoGT-25
(page to me... woo hoo)
hate to ruin all your fun but if u look under user options, u can have 5, 10, 20, 30 or 40 posts per page... so for ppl like me who have 40 posts per page... your "page to me" means bullshit..
just thought i would let you know :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
