Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest Boxhead
ROSS -- here is my tweaked version of the draft, feel free to tweak it more.
Ok people - after discussions with boxhead, the cruise is proposed to be:
Meet: Mudgerrebah Shell Service Station
Date: Sunday 6th July
Time: 9:30am - Leave - 10am
We will follow the Mad Mountain route through Hinze Dam, then on to glow worms then down to Fingal Head where there is a BBQ area and carpark. After we finish up there, we can all cruise back up to the Gold Coast and could meet again or go our separate ways.
We decided to not drive down to Byron Bay as there is no BBQ area or carpark big enough coz it is so busy on weekends.
Could everyone confirm that they can make it. as we will not wait for people we dont know are coming.
Also UHF's are preferable if you dont want to get lost, and to notify of school girls on footpaths. the channel will be decided on the day
Cheers
Ross
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
