Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
had a bloke try to race me in his brand new vx ss. boor bloke musta been dissapointed with his buy. i pushed him the whole way - right up to 190 and he was fully on the loud pedal and the 33 was just on boost. those things cant corner either....
more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods. more mods.
i think i only got 1 point left now. i havent changed my license to nsw yet and i went thru' a fixed speed camera. OOPS! 68 in a 60 i think so yeah, i need to be careful. thing is ive gotten into the habit of hitting that thingo that doesnt let you go any faster on the way home from work everyday lately..... better wake up to myself.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
