Exhaust
Guest andrewjread
I know this is probab a common question but what would a 3" exhaust from the cat back roughly cost for a R33 and is this what I should get. I dont give a shit about brand names or noise....just performance.
Heres a hard decision. Should I fork out for the exhaust, or get some nice rims and tyres first. decisions, decisions....
https://www.sau.com.au/forums/topic/10961-exhaust/
Yes but without a bigger cat , either hiflow ( yes I know rev210 )or some larger flanges it is probably going to be a minimal performance gain.
I believe there is good gains to be made from a quality dump off the turbo.
Cheers
Ken
https://www.sau.com.au/forums/topic/10961-exhaust/#findComment-179686
I would suggest saving up and getting it all done at once.
Doing it bit by bit will invariably cost more because some stuff will have to be done again ( placing on the hoist , removing pipes , replacing gaskets etc )
Cheers
Ken
https://www.sau.com.au/forums/topic/10961-exhaust/#findComment-179701
Depends where you go , Stainless or mild steel , mandrel or press bent, Tig welded or mig, show quality or whatever.
Confused you enough yet??
Search some past recent threads in the W A section re. exactly the same thing.
Cheers
Ken
https://www.sau.com.au/forums/topic/10961-exhaust/#findComment-179714
For a non-brand name system, then your looking at about $1400 for a complete system, but shop around and you can save yourself some money.
I have just made my system very hiflow, and the car feels the better for it. Definately do it all at once, just keep saving your money.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10961-exhaust/#findComment-179750
I have an jap made apexi N1 system (its not an apexi and doesnt wear the same price tag) Jeff Ash from c-red can organise one for you, about $1k from the cat back. I've taken beeble for a drive and he reckons they are tops as. Good looking unit and the in car noise is quite minimal, plus you should pickup around 15kw at the wheels. Rev210 went to quickfit exhausts in morley and they did a dump+front pipe for around $400, so once thats all on expect maybe a 20kw @ wheels gain, plus a tad more boost.
https://www.sau.com.au/forums/topic/10961-exhaust/#findComment-179900
I need some help with my exhaust parts.
I have a cat-back (i think) kakimoto exhaust seen here:
http://www.perfectrun.com.au/performance%2...fflerRslash.htm
You can see the 2 bits there, they are both joined, so i have 2 mufflers.
Then the pipe goes to the a little round thing where it appears the o2 sensor is (I dunno what its called) and then it goes to the turbo.
I want to put the front pipe + cat shown here
http://radium.highway1.com.au/parts/
Do you guys think it will fit, work and make a difference?
https://www.sau.com.au/forums/topic/10961-exhaust/#findComment-187068
Cat? That looks like a cat remover to me:p
It won't necessarily fit, but could be easily joined by any of the local exhaust shops. I would remove the centre muffler to give it better flow and better noise. It will definately make a difference.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10961-exhaust/#findComment-187687
unless you buy a completely stock car, alot of tyhe imports have these small mods done to them, exhaust, rims, pod filter etc. i bought mine when it had been modified to all hell and although a few parts have broken or fallen off the value cannot be argued. my cars got an apexi N1 with 3" off the turbo and 4" cat back, very nice exhaust.
https://www.sau.com.au/forums/topic/10961-exhaust/#findComment-189389
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
