On that note of ECU's and motor swaps...
The series 2 motor doesn't run the ignitor on the top of it, it's run from the ECU. How did your mechanic get around this? Swap ECU's, or do something funky with another ignitor?
That is not right, the ignition amplifier is built into each coil on a series 2, not the ECU. The ignition output stage of a series 1 and 2 ECU are exactly the same. That is why there is only one version of the PFC for the R33 RB25DET.
I would be checking the ECU for fault codes, also check that the knock sensors are working and plugged into the ecu.
I have a feeling the guy who sold me the motor was taliking it up because i found the ignition ignitor on top of the head so it musnt be a series two motor i guess.
Sorry to shoot you guys down in flames! hahah. You seemed so proud of yourselves too.
Is throttle response a bit slower with a front mount added to a rb25det?
I have to get this thing looked at. Its hard finding a good mechanic on the gold coast aswell. I find it hard to trust them after having my dad fix all my cars in the past.
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
