Hey Everyone
I know I might be on the wrong website but the level of knowledge on this forum seems so vast I'm hoping someone can at least point me in the right direction :
I've got a Datsun 260Z coupe I am currently doing up and I want to put airconditioning in it. Does anyone know who I can call about doing this. Also, does anyone have an idea as to what this might cost?
Cheers Heaps!
Stu
https://www.sau.com.au/forums/topic/109727-datsun-airconditioning/
Not too sure....maybe try a Z forum? Short of trying to adapt aircon from another datsun model that you could get from a wrecker, I'm outta ideas.
I do know of a certain SAU Vic member who rebuilt his 260Z from the ground up....don't know if he's got aircon (I doubt it) but he might be able to point you in the right direction....forum name is RPMZ, do a search and send him a PM.
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
