Hi,
Ok this is really frustrating me..
Only started happening about 2 - 3 days ago. When i turn on my headlights, my front left light seems to turn on at random times. For example if i turn on my headlights fully, my parkers will turn on, then only the right headlight turns on. I'll turn them off, then turn them back on, then both headlights will come on..
Turn em off and back on again, and then only right side..
Its like the headlight just turns on whenever it feels like it.
Sometimes my front right doesnt turn off and my front left does.
Any ideas? Could it be my battery or something?
I've done heaps of fiddling with all the connections and still havent found anything..
https://www.sau.com.au/forums/topic/109756-r32-headlight-problem/
Sounds like the actual dash switch needs to be pulled apart and the contacts cleaned, very common problem in the R32s. The contacts gradually wear and the contact resistance increases to the point where the lights will work intermittantly. Clean the contacts carefully and you should get some renewed life out of the switch.
Cheers
oh ok
well i'm a bit of a noob, how do i go about doing that?
Cheers.
You will have to undo the instrument surround with the light switch and pulling it forward or out completely (easiest solution) you can then access the 3 screws that hold the switch in place. Once you remove the switch carefully open it with a screwdriver. There are 3 thin and long contacts (from memory) which pivot like at seesaw and make contact with some copper pads. You will need to remove the long contacts and with a nail file or similar carefully clean any carbon deposit on the contacts and copper pads. Reassembly and test before putting the switch back in place.
The headlight main feed passes through the switch so any reasonable resistance across the contacts will result in intermittent operation of the headlights.
Hope this helps.
Cheers
SLO32 is right. i have exact same problem on my 32. havent fixed it yet(gotta get my car runnin first :P ), but checked it. the white plug looks as if its been fried a little on mine. hopefully yours aint that bad. The surround aint hard to take off. there are two screws under the cluster surround to unscrew. then there are four on these plastic panels kinda where your knees sit. Pull this panel down a bit and then i think there are two more screws. im pretty sure all 32's have same dash layout. where your light switch is you should then be able to have a look at the plug and clean it
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
