Hey guys,
Im getting a SAFC2 soon and I was wondering if any of you know any good tuners around the northside area that would be able to tune it for me?
I tried a search but for some reason the function doesnt seem to work properly on my work computer.
Thanks
Chris
https://www.sau.com.au/forums/topic/109812-tuners-in-northside-area/
I would recommend Allstar Tuning and Performance at Zillmere. They just installed and tuned my Haltech E11V2 and have looked after my car since it got here in Feb 2004. Talk to Richard (owner) or Daniel. They really know their stuff.
second that i got a Haltech E11V2 in my GTR installed by richard @ Allstar. great guys to deal with
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
