/\/orthside - Dinner - Tuesday 4th March
easy...
To get there, go down Centenial drive from Chatswood, past Hunters Hill and over Gladesville bridge. Turn Right at lights at end of bridge, follow this road to Lyon's Road. Turn Right onto Lyons Rd, follow for about 1km. Turn Right onto Hampden Rd, follow to end. Restaurant is just to the left on Great North Rd.
