Hi guys been having problem with my R32 GTST lately, just some info on it first, stock turbo, gtr front mount, turbosmart bleed valve, pod filter, 3 inch turbo back exhaust, apexi bov.
The problem im having is very intermittent sometimes I can drive with no problems for a whole day ,ive only noticed it happening when the cars warm but sometimes when im around 2000rpm in any gear the car just loses all power, I can put my foot flat to the floor and nothing will happen and then all of a sudden it will jump to 3000rpm then no higher, sometimes after this happens I wait a few seconds then its fine other times it will then stall, when I try to restart the car it is very hard to start and needs me to rev it as its cranking over, sometimes once its restarted it will work fine again and sometimes the whole process will repeat itself, it can happen any time even while cruising along in say 4th the revs will just get stuck around 3k.
Ive also noticed since this problem started the car is idling quite low sometimes around 400rpm.
Any suggestions what it could be as its doing my head in,
thanks guys.
Hey Guys,
Dave & I cleaned the AFM on his car last night. So far it seems a bit better but time will tell as it hasn't been taken for a good drive yet. Will let you know how that goes. If you have any further suggestions or comments let us know!
FYI; It's running 11psi.
Ryan
Edited by d0p3y
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
