have searched...
basically i have some ringland issues so a full rebuild is in order.
i have allready got forged pistons, and forged h beam rods,
and have sent the motor off to get bored, and crank balanced etc.
now my general question more refered to what else shoud i do while its apart.
my car is a r33 s1 4 door auto.
consists of
full 3 inch exhaust turbo back
high flow cat
600x300x80 fmic
gt3076r-sp
stainless exhaust manifold
nismo 550cc injectors
q45 afm
power fc
walbro pump
sard fuel reg
MV Automatic shift kit
Any suggestions?
cams?
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2036706
Hi mate..
I've just finished rebuilding my RB25DET engine. I've now done 7,000kms and haven't had any major problems (touch wood!)
While the engine is apart, I would change your water pump (about $40-$50), def change the thermostat (under $50)... you could do the oil pump if you wanted to, I didn't though...
You gonna change your clutch while it's all apart? I think it was called the 'thrust bearing'.... replace that... aparently the 'piolt bush' should be replaced as well...
Are you going to build the engine yourself?
If you've got any questions... just ask me.. I'd be more then happy to help.. I've been there and done that so fire away with any questions you have and I'll do my best to guide you in the right direction.
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2037155
I don't know that turbo so I don't know how far you are expecting it to take you but I would suggest you ditch that fuel pump and put something decent in there.
Tomei Poncams (type B) are good.
I wouldn't port the head but a polish of the combustion chamber would be worthwhile.
I would have expected things like water pumps and oil pumps would be replaced as a matter of course.
Put a crank collar on for the oil pump drive if going over say 250rwkw.
Have you thought about what compression ratio you are going to run?
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2037819
How much did it cost you?
Did you do it yourself or workshop - which one?
Standard new parts or heavy duty after market stuff?
What power you got now?
Hi mate..
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2037884
RB26 cylinder head= 2 oil feed galleries between the block and the head
We block one off, same as RB26's are standard
We use a 1.5 mm restrictor in the other
Plenty of oil flow to the camshaft bearings, not too much oil slopping around in the head, getting chucked into the catch can and leaving the sump in short supply.
RB25 with VVT= 2 oil feed galleries between the block and the head
Plus 1 feed to the VVT actuator
Plus leave the VVT oil feed as per standard
Plenty of oil flow to the camshaft bearings and VVT actuator but not too much oil slopping around in the head, getting chucked into the catch can and leaving the sump in short supply.
RB25 without VVT= 2 oil feed galleries between the block and the head
We use a 2.0 mm restrictor in the other
Plus block off the VVT oil feed
Plenty of oil flow to the camshaft bearings, no VVT actuator. Not too much oil slopping around in the head, getting chucked into the catch can and leaving the sump in short supply.
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2038115
the head has had a full three angle valve grind, and all stem seals replaced.
i was more thinking down the track changing to a rb26 head..
due to big cams and lifters..
will they bolt straight on?
my original question i was wondering if any one else has done the full rebuild,
how much grunt?
did you lift the standard 7000 rpm limiter to 7500 or 8000 with new rods and pistons?
any other experiences?
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2040782
well i got 582.7hp out of my rb25 and thats without nos
depending what funds you have.
head
tomi cams 270 deg with 10.5mm lift
ferrera double valve springs
ferera 2mm oversize valves
solid buckets
cutom lifters
wesco conrods
race bearings drilled
heat treated stnd crank je rings
cp pistons
extra oil galleries
n1 oil pump
n1 waterpump
bored out 20thou
everything port and polished
flow tested..
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2041160
Hi mate... in answer to your question.. I built the engine myself but got the machining done by pro's..
All up I spent about $7,000 and I did put heavy duty parts in because I'm aiming to get 300 at the wheels.
After I had run the engine in.. I had it dynoed and running about 9PSI with stock intercooler, I got 176kw at wheels... not bad I thought..
I've now brought a Hybrid front mount and will soon buy an aftermarket ECU, then I will probably run 15 - 20 PSI through it and see how much power I get then...
I did post up a thread here a few months back on my entire rebuild.. I can't remember what I called it but search and you might have soome luck...
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2043750
take note about replacing valve springs, even smaller cams 256 with 8.5mm lift require more seat pressure.
standard springs start to fall over when you make around 275-280kw at tyres. a decent turbo pushing 20psi will overpowrer them. seems like you have downstairs sorted, but all the power is made upstairs.
head
solid buckets
cutom lifters
wesco conrods
cp pistons
extra oil galleries
n1 oil pump
n1 waterpump
bored out 20thou
flow tested..
>_<
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2046642
just on the quiet, if your looking to push that much boost through it I suggest you sell your Hybrid & buy a quality, more efficient core for it.
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2046645
solid buckets
cutom lifters
would love to get some details on how much and where you got the above parts from..
looking into this kind of setup on a rb25/30 but the tomei rplacement valve springs and solid lifters are unavailable.
cheers
https://www.sau.com.au/forums/topic/110518-rb25det-rebuild/#findComment-2046667
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
