Eastern Creek Half day Drive day THURSDAY 3rd April.
Originally posted by fatz
i wouldnt let that bucket on the road it i had my way cant even keep up with a r31 gts in the nasho park in the rain without running off the road
Are you talking about the time you spun on the very next corner?:shake:
  • Replies 149
Just to remind everybody,
Date: Thursday 3rd of April 2003
Time: 1 - 5pm (need to be at the track no later than 12:15pm to sign up)
Venue: Eastern Creek Raceway
Event: Track day organised through MOTO CONCEPTS
Cost: If we have more than 15 = $130 per car.
If we have less than 15 = $140 per car.
Deposits need to be payed before Sunday 23rd March 2003
Passnegers: $20 for unlimited rides (need to bring long gear and helmut)
Event "Debriefing": To be conducted at the Cricketers Arms at the conclusion of the days track activity.
Intrested people (deposits indicated in brackets):
Majanal
Roy ($50 24/2/03)
Silver-Arrowz (scratching)
Merli ($50 dep 17/3/03)
Duncan ($50 dep 18/3/03)
Kel ($50 dep 18/3/03)
Dazsta
Carlo ($50 dep 19/3/03)
fatz
scott d ($50 dep 18/3/03)
drifto ($50 dep with dino)
Hey Dan, just so you know, I won't be participating in this one (sorry, just noticed my name on the possible list). It's possible I may spectate, but that'll only be if I can get the time off work.
Have fun either way, hope the weather holds out for you all. :mad:
Tex
yeah silver... you are just being soft... I have confidence that you will wake up to yourself and get on the track... I have only $12 to my name at the moment... but I'm gonna rob a bank on the way in... I haven't been on a race track this year...that is bad.
Come along... but as I have said from the beging, only those with deposits payed have had spots booked. I know that the day is full, but Dave said he would hold 15 spots for us and we are only currently using 9 of these... so you should definatly get a shot this time.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
