hey guys,
Anyone who has any experience with wiring up indicators (the small orange ones in 400R bar) and park lights?
Just got car back with new motor and cant afford auto electrician so im going to to tackle it myself.
Car was in a smash and park lights have not been wired up since new head lights were fitted.
Help ? anyone?
maintenance or the general discussion areas. but oh well
hard to tell you how to wire it, since i cant see whats missing.
when i installed the blinkers in my 400r bar i cut the std Mspec lights plug of and wired into the new lights.. that way i could use the factory plugs to be able to unplug them when the bar comes off.
parkers, they are simply the smallest plug there.. it should be just a matter of putting the connection onto the back of the globe. once again. not enough info to tell you what needs to be done
yeah thanks man,
I got the parkers working. I couldnt find they passenger side factory plug anywhere that goes into the light, so i wired it from the drivers side and ran a wire across. A bit backyard but it works and the car doesnt know any different.
The blinkers in the front I just cut off factory plugs and crimped on some multi conectors (3 for the threee wires) and heat shrunk them all together and conected it up.
So its all done thanks anyway man. One thing after another with this car lately. I was thinking of selling it but just about everything has gone wrong with it lately so it should be reliable now hopefully. Wouldnt mind a gtr however.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
