Hey guys, I'm looking into getting a new set of semis for the Buddy Club rims I've got for track days. The wheels are 17", 8" width front, 9" rear, the usual deal for a GT-T / GTSt.
They currently have a pretty much rooted set of Dunlop Formula D01Js on them now (fronts down to the wear bars), 235/45 on the front and 265/40 on the rear (which *just* clears the guards).
Now in pricing some tyres today one of the recommendations from a tyre place in Brisbane was to go for 245/45 on all four wheels. I know we're only talking 10 or 20mm here but is this a good idea? A better idea than having different widths front/rear?
This place also recommended Falken RT615s but from what I understand these are a street/race tyre and I was thinking more along the lines of Bridgestone RE55, Dunlop D01J or DZ02G or maybe Yoko A048s - I'm pretty sure those Falkens don't really compare to them!
Anyway should I go diff sizes front-rear or the 245s on all corners?
https://www.sau.com.au/forums/topic/110885-semis-recommended-size-for-89-rims/
personally, I'd be going for maybe a 235/45/17 up front and a 255/40/17 up the back. If you've got room for bigger rubber up the back you may as well use it.
The reason I bought 17x8 and 17x10 algernons for my car instead of the TE37's I was going to get was simply because I didn't want to run 245/255's all round
But that's not the issue, the problem is the corner entry understeer generated by using narrower tyres on the front. In addition you are compromising the braking performance by limiting the front tyre size. The extra width on the rear means using a lower profile tyre on the rear, exactly what you don’t want. A more compliant sidewall is required on the rear for improved power down. Conversely you want a less compliant sidewall on the front for improved steering response.
The truth is you should be using 9” rims all round with the same size tyres on all 4 corners. Since you already have 8” rims for the front you need to use the right size tyre for that rim, hence 245/40/17. This then means using the same size for the rear to achieve some semblance of balance.
Hope that made sense
:P cheers :D
One would suggest that there just might be a more scientific reason for wider rear wheels than the "wank factor", especially when it is common place on BMWs, Merc., Ferrari, Lambo, porsche etc. etc.
I would imagine the logistics would go along the lines of= A car only wieghs so much and requires a standard of tyre and width of tyre to brake and handle to the manufacturers specifications.
2. the rear tyre has a slightly different roll of handling also but trying to tame 250-300+Kw while doing it. Hence much wider. I Know on an M3 if a skinnier tyre is fitted on the back of the same make (michies usually) you can break the car into wheel spin in a straight line just by planting the throttle but with the correct size rim/tyre on, it won't.
I'm sure some one will correct me but cars that require wider tyres on the rear have a high power to wieght ratio and need the extra traction other wise the car becomes undrivable and useless to the average driver.
M3, Ferrari, Lambo, Porsche
Those examples have fundamental differences to a Skyline;
M3 = 50/50 weight distibution and high power rear wheel drive
Ferrari = mid engine and high power rear wheel drive
Lambo = mid engine and high power rear wheel drive
Porsche = rear engine and high power rear wheel drive
what about cars that aren't so front heavy, such as 180sx's??
They have MacPherson strut front suspension, not double wishbone. So there are a whole pile of dynamic issues (camber change, strut stiction, SAI etc) that make a direct comparison quite complex.
:( cheers :dry:
look into the legality of it .. by law ya sposedto have same size rim and tyre all round on ya car
Yep, that's the ADR. But Porsche, Ferrari, BMW, Mercedes, Lamborghini, Maserati, Honda (NSX) etc don't worry about it. It's one of those "letter of the law" but "we will ignore it" things.
:wub: cheers :(
:D cheers :D
so what do you recommend for a 180sx with stock guards, in terms of wheel width and tyre sizes ?
The widest that will fit, same size front and rear and don't lower it too much, it really stuffs up the geometry.
:P Cheers :rofl:
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
