Ah ok, yeah I see exactly what you mean. So this means that an engine has to flow exactly X amount of air to make X amount of horsepower, so therefore a turbo that flows 38LBS/Min = approximately the amount of air required to create 380HP of power?
The way Garrett and most other turbo manufacturers rate there turbos is as follows.
They run up the compressor until the pressure ratio is exactly 2.0, that is exactly 14.7 psi boost. They then steadily increase the airflow up past the efficiency peak until the adiabatic efficiency drops back to 60%.
You can do it yourself by eyeballing a flow map. Draw a horizontal line at 2.0 pressure ratio, and note where it crosses the 60% island on the map in the choke region (to the right). Then drop a vertical line down to indicate flow.
Engine power is assumed to be one Hp for each 1.5 CFM at that operating condition.
It is just one standardised operating point on the whole flow map to very roughly compare one compressors flow capacity to another compressors flow capacity. An actual real engine may operate a long way from both 14.7 psi boost, and the 60% efficiency point on the map. But it is still a pretty good average operating point to choose.
The exhaust turbine flow, or back pressure, does not come into this at all, but is also extremely important for the engine.
Actually you will find that most compressor maps are graduated in pressure ratio vs the mass of the air pumped in lbs/min . The problem with measuring airflow in cfm is that it gives no clue as to the air temperature and therefore density .
Because of the mores law factor the maximum choke flow is usually considered to be what the compressor can dish out and horsepower worked from ~ 10-11 Hp per pound of air .
This really is a nonsensical way to rate a turbochargers power or I should say mass airflow potential . It makes the huge assumption that the turbine can get the compressor/housing combination to perform as it did on the test flow rig . All too often it can't so the result is not an accurate real world achievable one .
Cheers A .
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
