SOLD
I've got an as-new Alpine head unit for sale. It came in my car when I bought it but I swapped it out for my trusty old head unit which I love and know so well I can control without even thinking or looking
Here are the specs from the Alpine site:
CDA-9853R Bass Engine Pro CD / MP3 / WMA Receiver / Changer Controller
This high-class head unit is extremely powerful and sophisticated. It features Alpine’s unrivaled Bass Engine Pro sound tuning, including 6-channel digital time correction and 5-band parametric equalizer.
50W x 4 High Power Amplifier
MP3/WMA Playback
MP3 ID3 Tag Display
i-Personalize
Bass Engine Pro
6 Position Digital Crossover
6-ch Adjustable Digital Time Correction
3 PreOuts
'05 Amplifier Link Ready
Ready for iPod
Vehicle Display Interface Ready
Multicolor Illumination
Remote Control
Max Tune SQ Tuner
5-Band Digital Parametric Equalizer
RDS Radio Data Display
Retail is $700, I'm after $250. I simply would rather have the money right now. Look at the prices of other Alpine head units being sold right now on here and see how good a deal this is. Pls don't bother making a lower offer, this is already crazy cheap. Works perfectly, looks like the previous owner had only installed it recently, as the box was in the boot, with the instructions and the case to hold the removable faceplate. Works perfectly, had a brief play with it while I had it in the car. I read up on it after swapping it and thought maybe I should have left it in there, but I can't be a$$ed opening up the dash etc again. Oops.
Send me a PM on here or an email (preferable) via my Profile. I can ship it anywhere in Australia, but buyer will pay shipping and I really suggest insurance just in case. Prefer direct deposit for payment, I can link you to my eBay feedback if you like (and you can email me using that address to confirm it's actually me).
Edited by sl33py
https://www.sau.com.au/forums/topic/110904-fs-as-new-alpine-cda-9853r/
What model is it? If it plays dvd's im very interested.
Cheers
err.. the model numbers in the description
Alpine CDA-9853R Bass Engine Pro CD / MP3 / WMA Receiver / Changer Controller
can u gaurantee its working order? and is it an aussie model or an overseas one? (can tell by checking if it plays AM radio or not). any scratches? how much is postage insurance? cheers.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
