Ive got a R32 GTR and ive taken out the ristrictor in the hose that goes to the boost controller solaniod but i was also told to join those 2 hoses together to get 15psi.. It works BUT like at 6000rpm its sometimes starts to make a limiter noise. could some one help me because my car is GOIN NUTS ON 15PSI :O
I was only running about 8-9psi before but now that little bit extra is awesome.
DO GTRS have a boost cut defender?
ANYONE?
Im only new to the forum so this is a pic of my car.
explain exactly what happens at this 6000rpm mark.
does it cut the power completely.. like is it violent?
is it like a rev limiter where it stutters and kinda back fires?
doest it keep reving up but kinda misses?
what happens to the boost gauge when this "CUT" happens? still sit at 15 or drop?
with more description and those answered, people can give you a better response as to what the problem is.
at the moment it could be..
AFM max
spark blowing out due to excess boost.
coil packs arc'ing out
etc...
I think that the fact that you now have about 2 x the boost you had before, you are blowing out the spark.
there are a few things you can try which will cost you nothing but some of your time.
1.) take out your spark plugs and gap them down to 0.8mm.
if they already are, drop them back to 0.7mm.
2.) with some electrical tape, tape up the coil packs. there is a guide on this in the maintenance section of these forums.
I did the above 2 points 2 weeks ago and my car revs out smoothly now.
mine is an rb20 but same edal.
runs a little more boost than stock.
I suggest you try the 2 things above as they are free and MAY fix the issue.
If you are in Sydney, I can help you do it if you like.
if they are anything like GTST's then yes they do.
Write it out 20 times..........
THERE IS NO SUCH THING AS BOOST CUT
Half way there……………
Hope you learnt a lesson, next time it will be detention for you
:O cheers :P
if you are running 15psi and stock ecu you will be encountering the STOCK EXCESS AIRFLOW protection. turn the boost down and try again, i would suggest around 10psi at the most. this should work around the excess airflow protection
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
