fitting an air filter
Mine needed an adaptor plate, i got that from autobarn.
i believe the apexi filter comes with the adapter to suit.
unless 33's are different to mine u will need an adaptor of some sort or you could run some screws through - i wouldnt, but some ppl have. Depends on filter setup though, you may not be able to screw into anything secure enough...
I got an O2 Rush and it bolted straight on to the AFM. Couldn't be easier. Just make sure the pod kit you get is to suit an R33. No mods required. Just be prepared for the sound! I thought I must have forgotten to re-attach a pipe or something when I took it for a test run. Love it now though!
pod filter + exhaust, i'd say yes the sound will make heads turn...I am going to make up a cai box for better cooling of intake air and to quieten the thing down a bit...you can clearly hear it with the windows up and stereo on too!
[it sounds like a have an aftermarket BOV, but i dont and personally wouldn't waste my money]
Dude, if you bought a *kit* that means you would have got an adapter [correct me if im wrong] with it to suit your car [r33] ~ I haven't modified anything on my car to fit a pod either. Your wording is likely to confuse someone that hasn't fitted a pod filter before!
Unless you can buy a pod with the screw holes already there? anyone care to enlighten me on this? Maybe 33's are different? I doubt it though...even commondoors need an adapter why would 33's be any different...
Yeah, I have a UAS cold air box, Pod filter + exhaust and aftermarket BOV which was on the car when I got it. I got my girlfriend to drive the car up the road away from me then towards me and you can hear the turbo spool up over the exhaust. As nismoR34 said it definately turns heads when the turbo spools up. Don't know whether the box quietens it though? I like the sound, others hate it. Its is all personal preference.
It still seems quiet to me. My previous car, a 72 GT Clubman mini, had twin SU's hard against the firewall, now thats loud!
I do like the sound too but when you are turning heads ~ sometimes those heads belong to Police/EPA/etc, and can be asking for trouble...which begs the question, are any of these things legal?
PODs: according to EPA you can have 1 intake mod, a pod thats NOT foam is okay but not the oil based from what I have heard. But what about police / vic roads do they care about pods? or the noise? *shrugs*
BOV: I am not 100% sure but I know people that have been told off for using them, and have heard that they are illegal if vented to atmosphere.
BC: An intake mod, so when used in addition to a pod [or after/m intercooler] it is not legal [only 1 mod allowed].
I think we need a FAQ section for these issues, written by people who have either obtained info from the relevant authorities or are the authorities themselves.
The O2 Rush is all one piece! There is no adapter piece. Just pull it out of the plastic, grab the nut and bolts from the AFM which bolt it to the original air box and bolt on the pod. Job finished!
http://202.139.242.57/Images%201/O2%20Rush...0Race%20pod.jpg
yeah ok then - the adapter is built into the pod ~ same as unifilter I believe...but they don't cost $30 like my pod either ;)
I personally can't justify spending 200-300 dollars on a pod that doesnt do that much to increase performance [compared to the cheaper ones]..call me a :shake: I dont care!
Guest silver33 guy
i read at the blitz UK website that expensive and cheap pod filters are different in the sense of the amount of air they let through.
then, i read at another thread in this forum that the pods that let a lot of air through dont filter the air much and that causes a lot more deposits in the AFM.
is this a compromise that we have to live with?
ps. the blitz filter was made from a metal mesh and like a few others, claims that its the best. but if you tell me that a $30 filter will do the same, hey, i'm not gonna spend $300 on a blitz!
I have read all of those tests on filters and personally dont see the point in spending $300. Sure they may look good or flow a bit better or even sound a certain way but I am happy [as are other friends] with my $30>40 Simota etc filter.
Stock turbo and engine only need a certain amount of flow anyway [there is such a thing as too much I believe], a pod provides a better flow than a panel - this has been proven. A lot of the expensive pods seem to fall into the *oil* category too which makes them non-epa compliant [illegal]. So no foam and no oil to be safe and legal...
If you are like me you won't let your filter [pod or otherwise] get dirty anyway ~ if it does and you cant clean it, buy another one! At $30 odd dollars a pop you'd be lucky to spend anywhere near the cost of the others, maybe in 10 years or so...
I have found this book very useful *21st Century Performance* by Julian Edgar. A lot of his articles from the book are found at www.autospeed.com.au plus other tests / reviews...buy the book or read through the website for info on air filters / turbos / boost / exhaust etc...
oh yeah, just be sure to read the packet the filter comes in > some of the really cheap ones [not simota] say *not suitable for use in turbo cars* I have come across this only once [a/barn], the filter will probably be fine but if it does stuff up - you can be sure there will be NO warranty coverage!
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
