I have 2 front guards off a ser 1 r33. silver in colour and in un-marked condtion.. $150 each.
Also the front grill from between the headlights...
And last of all, clear indicators for the front guards.. $60 for the pair.
If anyone is after just about anything skyline I can get my hands on it.
No , I am not a shop! I have very good contacts in the import world and I get things way cheaper than what most people would pay.
So if I can help you out let me know... But please dont flood me all at once.
https://www.sau.com.au/forums/topic/11162-r33-ser-1-parts/
  • Replies 43
Grill, $60.
As for all the other stuff you guys want, I have made a list and should have an answer over the weekend....... Unless I am tied up fitting a new HUGE exhaust and nismo strut brace to some lucky Skyline owner from these forums......:P
https://www.sau.com.au/forums/topic/11162-r33-ser-1-parts/#findComment-187191
Woohoo! :) You will indeed be tied up...no not that kind of tied up ;)
BTW i want first dibs on any side skirts u come across in red :D :D
https://www.sau.com.au/forums/topic/11162-r33-ser-1-parts/#findComment-187767
Just for all you nice peoples on here, I have been in contact with my mate and he is going to see about all your parts and give me a list of what else he has and what is comming in soon...
Shell: You can tie me up any day !!!! :uh-huh: Dont worry about workin on your car....
https://www.sau.com.au/forums/topic/11162-r33-ser-1-parts/#findComment-187874
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
