my first post described the initial problem i was having... http://www.skylinesaustralia.com/forums/in...howtopic=111605
so basically for no reason the car would almost stall (or actually stall) and then when it was re-started would idle about 2000rpm and then bounce between 1000 and 2000rpm... It sort of sounds like "limp-home mode"
then if i wait about 1-5min or if i shut it off and start it again soon, it would go back to normal.
I tried resetting the ECU and then cleaning my AFM yesterday, but the problem happened again today, so its not simply a 'dirty AFM'
BUT... this time it happened, i had my laptop (with nissan datacscan) with me! i plugged it in (but could not display the values for some reason?). i could, however, do a diagnostics test. It came up with AFM faulty
SO MY QUESTION IS THIS:
given people's ast experiences with AFMs, and that this problem seems to be intermittant rather than full time, is it likely to be
a) faulty AFM - has it happened before like this?
b) break in wire to AFM - thus ECU sees no signal
c) faulty ECU - somehow shorted the AFM circiut on the ecu board.. unlikely, as the problem is intermittant
And, if its the AFM unit itself, can i get a new one from nissan, and if so how much? or am i best to find a second hand one and hoping for a fully working unit?
I'm personally thinking its a dodgy solder in the AFM which has come loose, and causing it to intermittantly fail
i would really like some help here guys, as my car isn't driveable until this is fixed
cheers in advance,
Warren.
https://www.sau.com.au/forums/topic/111844-ecu-diagnostics-afm-came-up-faulty/
Dont bother buying a new one the old can be fix fairly easily and cheap.
Just get a nife and cut the top rubber seal out and remove the plastic cover.(Take your time as its a pain in the neck).
Then once the top is removed you will see a copper cover that is soldered onto the afm's circuit board box(also copper) Just desolder its join and take it out.
Now where the plug is you will see that it has 5 pins that go into a fork like peice of metal.
It is soldered to this and these joints tend to fail and require resoldering. Use a fine tipped soldering iron and resolder these joins. This fixes the afm probs 9 times out of ten.
Once done test it and if ok resilicon the top in and away you go.
I have done this to:-
my afm R32
My brothers AFM R32
My mates Subaru Liberties afm
And my mates 300xz afm and it has fixed them all.
If you know you afm is farked then give it ago as you will have nothing to loose.
Good luck and hope this helps.
As above possibly dry/cracked solder joints.
If the AFM circuit board looks ok. It can't hurt to check the wires for continuity as well to rule out potential breaks somewhere.
If all the above fails get a s/hand one off here from $50-$100 on average.
thanks heaps for your help guys
i only have moderate soldering experience, but want to give this a go tomorrow...
off to buy a fine-tipped soldering iron! (and some solder)
cheers,
Warren
Dicksmith or jaycar sell them for sfa.
You wont need an ultra fine tip just the common ones found at the above places.
When I get a chance I will put up a diy to fix an afm with pics and everything. Most likely after easter when I get my car back.
When/if u change to z32 afm you can actually use the same procedure to swap over the afm plugs so the Z32 plugs staright into you stock loom. Anyway enough of me rambleing on have fun and good luck.
ok i re-soldered it this afternon, plugged it back in, and it starts.. which is the first plus - that i didn't stuff anything else up
now to give it a test drive.. will post the results of how i go tomorrow
might also write a little "how-to" document as i took a couple of pics as i was going..
cheers,
Warren
  • 1 month later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
