Hi all, I am new to the forum, and pretty new to Skylines in general. I am looking at purchasing an R33 GTR in the not-too-distant future.
My question is, how hard is it to get 350-400hp @ the wheels from an R33 GTR?
I will be doing the obligitory FMIC and exhaust mods, but what else do I need.
Is it just a matter of adding a bit more boost or is it not that simple?
Can it be done on the standard turbos?
Would this be a safe power level for an internally stock RB26?
How would the gearbox cope?
What boost does a GTR run from factory?
I am basically after a package that will give me reliable power, enough to run low 12s (at least - 11s would be better) consistantly and reliably.
I did a search before posting this, but I couldn't find any decent posts to answer these questions. If this is a stupid question that has been asked countless times before, please point me in the right direction.
Any help would be appreciated.
https://www.sau.com.au/forums/topic/112508-400rwhp-from-r33-gtr/
You dont need 400hp to run 11's in a gtr .
You need turbos ( stockers are ceramic, very easy to drop an exhaust wheel and take the engine with them),
full exhaust, power f/c and ebc. YOu dont need another cooller for mild mods .
Ok, so the main thing is to replace the turbos.
Sorry, I am new to this, what do you mean by power f/c and ebc?
I am really only after mild mods, I really don't want to go into rebuilding the engine with different internals, new cams etc. I have been through that with my VN, I would rather stick to bolt on mods.
I think that low 12s from a daily street driven skyline would be more than adequate, how much power should I be aiming for to achieve this? Maybe 300hp @ wheels?
You won't get 400 rwhp on stock turbo's probably max to around 350 rwhp.
I would advise exhaust with split dumps, air filters/intake, PFC with EBC,adj cam gears and FMIC. With these things and good tuning you should be able to run around 1 bar boost and around 350RWHP. That should get you your low 12's that you want. Any more power will need turbo(s), clutch upgrade and re-build to run safely 400RWHP.
[/quote
Power f/c is an aftermarket computer ( programable), EBC= electronic boost controler.
These are very mild mods, but with them and a good tune she will be good for a high 11 second pass @115 mph .
As for the power on the wheels it will depend on how happy the dyno is, dont take to much notice on the power she will make on the dyno .
Thanks guys, thats a big help.
I figure if I am going to rebuild the engine and replace the turbos, I may as well stick with V8 Commodores, so I think I will try to stick to bolt on mods with around 300rwhp or so in a GTR, which should be good for mid 12s I would think.
I know that dynos can vary, I am not overly worried about figures, more just the actual performance of it.
Edited by Quinny
Cheers, I have heard of GTRs making big HP on "stock" engines. In my case, I am not after a drag car, just a quick, reliable streeter (that will occasionally get taken to WSID). It sounds like 400rwhp is pushing the limits of a stock engine and definitely past the limit of the stock turbos, so I think that if I stick to around the 300-350rwhp mark, I should be pretty right - but it is nice to know there is room for improvement if I get a bit more adventurous.
One more question: How much boost does a GTR run in stock form. Some people say 7psi, some say 12..... can anyone shed any light?
Stock 10psi
dont push your ceramics over 15psi or 'rattle rattle' noise in your cat convertor is a ceramic turbine wheel
Go a set of Nismo N1's or Trust T517z's or HKS2530's-then bring on 22psi!!!-with comp and fuel upgrades of course
Stock 10psi
Thanks mate, I was wodering how much boost the standard turbos will take. How much power can the standard fuel system cope with? Will I need to upgrade the injectors, fuel pump, regulator or anything for 350rwhp?
Sorry for all the questions, I want to try and learn as much about these cars as I can before I go and buy one. I will have plenty more questions yet. I have been playing with Commodores for the past few years so this is kind of a new area of the performance market for me.
everyone says to pump heaps into the engine,
what about adjusting the camber??? to its flat on the road, droping the psi in the tyres... plus other mods like exhaust, boost, ecu, tune with race fuel. should run in high 11's
dont belive me, i seen it in that "motor active" dvd i got free with my tech wax!!
I don't want to go too nuts on the car, I basically want a package that is pretty quick, reliable and can be driven anytime, so race fuel is out, and as I said before, I am not after a drag car.
I want to get a stock GTR (hard to find), and I don't want to have to spend heaps of money on it.
I think the basic FMIC, exhaust, computer and boost upgrades will suffice for performance, maybe 300rwhp on 12-13psi?
I really don't want to have to keep throwning money at the car, and I don't really want to go to the extent of rebuilding the engine with forged internals and replacing the turbos.
It seems that the GTR engine has been hyped up to be tougher than it really is, and I have overestimated its capability to make easy power. Non-the-less, the R33 GTR is a nice car, and one that I have wanted for quite a while, so I still want one (and will very likely buy one soon), I just can't go as nuts as I planned to.
Edited by Quinny
hey Ben,
I bought my previous GTR stock as a rock (stock exhaust).
first thing I did was replace the stock clutch as it was a bit worn.
next I put it on the dyno which put out something like 150awkw, and the stock boost was showing 12psi. we pulled out the boost restrictor (30 sec job) and boost went upto 14.5psi and power 170awkw. at this stage the car ran 12.8@ 106. On another dyno it showed 195rwkw.
most guys here can push an easy 250-270rwkw from there standard turboed gtr's without spending big bucks. there an awesome car to drive around and easy to get good power out of them reliably.
hi champ ive got a 33 gtr and it got dynoed at 251kw atrw. Mods were zorst,1 bar boost and cam gears.
Times i cant tell you yet but if weather is permiting ill tell you 2morrow since im going to calder.
Id be expecting a mid to high 12s..Ill fill u in when i get the time.
Hope it goes well, mid 12s should be a walk in the park with 250rwkw in a GTR. I know several Commodores with around 300rwhp (225rwkw) that run high 12s, so I reckon a GTR would be better again.
Let me know how it goes.
Over the years i had a few gtrs, the closest that comes to mind was a 95 model v-spc, only mods full exhaust ( stock dumps), power f/c and ebc running 14 psi on stock turbos. She did a couple 12.3 down the wsid 1/4 . Another 33 ( none v-spec ) with the above mods + N1 turbos, stock dumps even stock airbox, she ran 11.7 @ wsid . Not difficult to run high 11's in a fairly stock gtr, much easier than a bommie and you can put the power ot the ground . I recomend you invest in a pair of turbos though, thats the weak link in the GTR's because they are ceramic wheels and not because of the size . Rb 26's are very strong and durable engines and in stock form will handle up to 450 p.s. at the flywheel, keep in mind they are only 2568cc not 5700 like the bommie .
Yes, but the commodore is naturally aspirated, where the GTR has 2 turbos making its power. In fact, the Holden V8 (not the stupid LS1) is not so different to an RB26 in terms of modification potential, they are both great engines, but make their power in different ways. Anyway, I didn't come here to discuss the virtues of GTRs vs Commodores.
Swapping the turbos does make sense, but it is an expense I wasn't really planning to outlay. It sounds like 350rwhp and low 12s or high 11s is a pretty good target for a relatively stock GTR.
Ok, I think I have a plan sorted now. Step 1: Find the right car to start playing with......
Its much cheaper to change turbos when you buy the car , rather than spit an exhaust wheel and change the turbos then + the engine . As i said before i dont go much on rwhp or awhp because dynos read differently so i dont quote power . When you do the 1/4 mile you cant cheat on power there .
I wouldnt compare a pushrod V8 with an RB26, totaly different donks but its your choice, if you like to compare them do so . I can tell you one thing you have to do a lot of mods to the V8 commie to even go near a lightly modded GTR and i speak from experiance here, even when you have the power in the commie you will have to use drag ryres to have any chance to even keep up with the GTR.
If you arte seriously looking for a stock 33 R give a p.m. i know someone that has a v-spec for sale at a keen price .
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
