hey guys, i just installed a walbro pump in my r33 gtst
it starts up, then dies, i dont know wats wrong wif it,
i do haf a power fc and aftermarket turbo and i hafnt had a dunyo tune
simply put, i start it up and runs for 5 seconds then it struggles and dies, is there a fuse or sumthing i hafe to up grade?
any help regarding this is greatly appriciated
https://www.sau.com.au/forums/topic/112842-help-walbro-fuel-pump/
when you replaced the fuel lines on the tank cap, did you put them on in the right places ?
Also when you turn the key to "ON" , can you hear the pump running? When you start the car, can you still hear the pump running ?
This happens consistently? That is, if you turn it off, turn it back on for a few seconds then start it runs again
for a few seconds?
If so, kink in the pressurised fuel line inside the tank, most likely. Enough fuel is getting there to start
but not maintain the motor.
Unfortunately you'll have to pull it back apart to see...
Regards,
Saliya
i dont think they like like the 2 stage voltage feed that is used for the factory one.
you need to hook a direct earth to pump negative.
also hook a direct 12v feed to the positive of the pump.
to bypass the factory fuel pump controler. so it gets a constant 12v feed.(the relay is next to the boot fuse box)
Correct the standard relay screws around with voltages (drops as low as 10v at times) with the standard pump. 99.9% of aftermarket pumps including the Bosch and Walbro ones dont like this and you will kill the pump fairly quickly.
I ran a completely new 12v feed to my Bosch 044 with a thicker gauge wire as I have also heard depending on condition, the amount of current aftermarket pumps can suck can well and truely overload what the stock wiring is capable of and get extremely hot/catch fire. Havent seen it first hand and it may simply be an old wives tale, but for the extra $50 it cost for my mechanic to do it, its cheap insurance.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
