  • Replies 52
17k is very low for a car like this - but have you tried to do a trade in - that might be your last option (if your getting the GTT from the dealer). Petrol prices have a lot to do with why this is still for sale. Good luck with it though...cant believe how cheap this car is!
Hey,
Nah the GT-T is well on it's way.
Need this money for compliance/rego/mods.
Still up for sale and still considering fair offers.....
$16,999
Or near offer/Negotiable!!
$16,999.......you will never find a GTO in this condition at this price for a long time!!!!!!!!!!!
  • 4 weeks later...
omfg - its still here?
heh.
Pulled it off the market for a bit, because I got the money I needed off my dad for the R34s compliance/clearance.
But yeah, I really have no need for the car now, so, i'm KEEN to sell.
As above. $16,500.
