First things first...welcome!!! Nice looking car you have there
Crap Isaac!! Alex, just go to your "My Controls" area and change it to whatever you want it to say!!
You can only change that if you are a mamber of the club!!!! I couldnt change mine till I had joined
thanks for the advice, I just go to the gym there and thought i would snap a couple of pics after i washed her today. (Isn't it annoying how many inperfections you find when you wash a car for the first time ?!?!)
Also, I was thinking of putting the car on the dyno just to see how it goes as a starting point and also to check out a noise im hearing (there is a high pitched whistle when the turbo spools up only happens for like a second on full boost between 4000 and 5000rpm i think it is). I rang up FIST performance and they quoted $95, does anyone have any dealings with them to speak of? or anyone else to recommend?
I have only heard very bad things about fist :O
I have only heard very bad things about fist :mage:
Thanks for the positive comments, there is definately an active community here.
I was actually wondering what they do in a "dyno tune" as opposed to a power run. Is it worth getting a tune if i have just the exhaust and hks pod?
Hi Alex
Welcome to teh forum :mage:
If you want to join SAu Qld please see this thread http://www.skylinesaustralia.com/forums/in...howtopic=104137
Feel free to PM me any questions you may have which I haven't covered
i'll let someone else explain the RB20E thing but basically its got to do with the amount of posts you've made on the forums
This is correct
This is also correct
Also, you don't need to be a member of SAu Qld to be able to change this :D
Rhinorebel mentioned Chilleh Night...basically we get together and have a dinner somewhere...check my sig for details -- hope you can come along :)
Kind regards,
Karen - SAu Qld Treasurer
FIST... well... as I personally haven't had any work done there, I can't say... but there are things that just don't sit right. They tend to not take things seriously. They will overcharge on items. And they tried to sell me a car which had work done and was tuned, yet still seemed to make piss-poor power figures.
Anyway, welcome, you should come along to Chilleh (it's at ChilLan this week) :mage:
Ciao, Anna xo
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
