When a clutch slips you can tell. Revs go up, speed stays the same....
im starting to get very bad clutch slip, in third gear it slips from the time it gets onto boost till it hits redline.
Spewing. Gotta change THAT now too!
Yes but how bad, i mean, surely with the mods he has, cracking a 13 with a slipping clutch is pretty awesome wouldnt you think? maybe too awesome?
As in your case, I thought a slipping clutch would have a very significant negative affect...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
