Wrecking Nissan Skyline GTR R32 1994 model for hit trafic lights in brisbane for test drive. front damage.
please do not ask me any front parts.
engine and gearbox take off from car.
Complete set GTR brakes and discs with aftermarket brake pads.........700
Driver side and passenger side guards, very good condition, no damage.........500
17" Wheels with rubbers.......one need fix, others good.........600
Door Trims .........excellent condition.......100 each
driver side and passenger side seats and rear seats..excellent condition......1100
Complete Doors with Windows.......excellent condition.......200 each
Tein adjustable suspension.........500.............. SOLD, wait for payment.
twin kakimoto exhaust system ........SOLD, want for payment.
others....
pics not include some parts bcz it still in car, will pick my car home then take them off on 18 April.
pm me and make offer PS. I am not a wrecking house and i do not know a lot of parts name.
buyer pay postage or pick up urself or buyer arrange postage if items are too big or too heavy.
thanks
brian.
Edited by Midnight Racer
https://www.sau.com.au/forums/topic/113448-please-closed/
  • Replies 41
err.....i need:
1) passenger side window switch.....
2) passenger side boot trim
also interested in ur kakimoto twin exhaust system...but just wondering what is the pipe size of it 80mm or 95mm???
can u plz pm me the price delivered to melbourne as well as the photo of cat back plz thank u
https://www.sau.com.au/forums/topic/113448-please-closed/#findComment-2092932
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
