Hey Guys,
PM's Replied...
New Parts Added
Lets get this stuff out of here.
Oh, and will swap for BOV if need be.
Cheers,
Dan.
  • Replies 125
Posted Images
I haven't got the cash for it yet, but yeah, I'm holding it for a guy at the moment, if it falls through I'll pm you.
No worries mate...
If it's not too much trouble, can u pm me even if you've sold it so I know what's going on
Cheers,
Phil
hey dan
so are those wheels and tyres sold?
cheers
manveer
Holding for someone pick up Friday... if no show they are your mate. ;)
No worries mate...
Cheers,
Phil
I'll do my best to remember Phil. :ermm:
hey
im after the front coil overs only not the rear. how much do u want for them ?
cheers steve
Don't really want to split them champ, see if you can find someone to buy the rears, or sell your rears and put mine in :);):down:
How much for the front coil overs ?
cheers steve
Geez man, at least give me 10 mins to respond... LOL.
Hey mate you wouldnt happen to have the little bracket that holds the charcoal cannister would you?
im desperate for one.
cheers
Actually I probably do, I'll try to remember to look tomorrow, remind me though... my memory is crap!
you haven't got a front grill have you?
No can do mate,
Sorry.
ABS is still for sale, I haven't included the sensors, but I can.
Pm's Replied.
Suspension out of car now... picks coming soon.
PM is best guys, I don't seem to be getting email notification of replies for this thread.
Cheers,
Dan.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
