  • Replies 57
bump just fitted new set of injectors from powerflowinjection this car is imaculate conditoin there is nothing wrong with this car wont find any in better nick
https://www.sau.com.au/forums/topic/113527-gtr-sold/page/3/#findComment-2208568
Was the problem with the car stuttering under acceleration fixed? I saw it from a previous thread you made.
na that was old post i think with the 33 gts it ended up being coil packs on that car but this is very tidy it makeing good compressoin, tested at nissan when bought it
https://www.sau.com.au/forums/topic/113527-gtr-sold/page/3/#findComment-2216644
also forgot to add when had clutch taken out it was the original clutch in there so it suggests that the k's havent been wound back and havent been thrashed if the stock clutch was still in there.also timing belt was checked and was replaced by previous owner,may had 100thousand km sevice but dont know, i still have clutch to prove its the original clutch
https://www.sau.com.au/forums/topic/113527-gtr-sold/page/3/#findComment-2216708
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
