As long as the AFR's are ok, and the fuel pump isnt dying, it will be fine.
fair enough but if you can tell me how to predict the life of a standard 15yo GTR fuel pump i will buy your weight in beer...
and drink it myself.
if you can afford it a nismo fuel pump gives you piece of mind that you have a reliable, new fuel pump in your car. injectors are a great idea too as even if they are not absolutely neccesary at this point they wont become obsolete when you upgrade further.
406hp, stock injectors etc is fine.
300rwkw from GTR injectors is not out of the limits.
Personally, leave the car as is. Simple.
Save the cash for rebuild and stuff and then wind the wick up when you have it all done.
you should last a long time on 300rwkw if you look after the car well.
I'm making less power than 300rwkw and i have seen 97% on my 550 Nismo injectors. I'm actauly making more power( average power) than him, i have a trap of 118 mph (11.8 et) . Looking at this i dont know how the 440's would cope, as for the pump its still good for a bit more, but i dont know about his 15 yo pump, mine is amlost new .
I'm also using smaller turbos than the 2860 garretts you have( gtss) so it would easy to max the 44os in that set up .
Hey Guys
Injectors: Definately going to step them up, I'll need them later (hope not sooner) anyway
Pump: 17 yr old pump, what could it hurt, I'll have to change it anyway for the rebuild. The nismo item seemed kinda pricey when a 044 flows similar numbers, but by the time i do the pump and all the rest of the extras it probably wont be that much cheaper. Plus it keeps the revenue raisers of my back when they want a stickybeak.
Forgive a nooby question...If I go with the Nismo item and 700cc injectors on this current combo will i need a fuel pressure reg seeing i'm not running the injectors close to their potential?
PS: Thanks SK for the "Aftermarket Fuel Rail" Post
Edited by Mr. Keets
Hey Guys
Nismo pump will be fine for the power you will be making with the stock reg .
good choice. nismo pump is nice and like most nismo parts goes straight in. no wiring or bracket mods needed. and flows more than enough to supply the 700s. as gerry pointed out there will be no need for an aftermarket reg.
I think you have something wrong somewhere if your making less than 300rwkw and maxing out 550's dude.
ferni, GT-SS, stock injectors approx 300rwkw
I believe rail pressure may have been bumped a little to get over the line, but thats on the limit now as i understand it with nothing left without going injectors etc.
I'll be using 550 for my GT-SS and there are definately not going to be on 97% duty.
Thats silly level of duty/risk
I intend be pushing them harder than ferni is so thats why i need them.
nismoid i think you are missing the point a little. duty cycle is influence by one thing only. the numbers the tuner inputs to the ECU. you could just about max out any injector at any power level you want. what generally happnes is that with bigger turbos more air is going in, so more fuel is needed (tuner adjusts the ecu to deliver) and as a result injector duty creeps higher it's not directly related to power. my car is reaching 100% duty at 253rwkw. BUT it runs a very safe (rich) tune for track use. saying that gerry running 97% duty is dangerous is a silly statement without knowing more about his set-up. he may be running at 97% duty but with an AFR of 11.5:1 (for whatever reason) which means he has a bit of headroom left.
Ah, but then to say that Mr. Keets needs to be careful as his larger than stock 550 injectors are maxed out under 300rwkw is essentially incorrect as the 550's support a much larger power figure.
If wrxhoon is running much richer than average tune thats his choice. Nothing wrong there at all by any means
But he should have posted that to give a fully informed choice for the information of the thread.
It all depends on how happy the dyno is too ! My point is, i have baby GT'ss turbos and i have 550's, yes i could get away with 440's with more pressure ( a bit risky though) .He has bigger turbos so 440's wont do the job. I'm only on 16 psi boost as well....
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
    • Came here to say, put all the wiring from the new motor and gearbox in that you can, then throw the stock ECUs in the bin, and get an aftermarket ECU. Should be pretty easy if you can use a multimeter and read a wiring diagram to then use a PNP aftermarket ECU to suit the motors wiring loom, and make the minimal changes you will to get it to work in with the body loom (If any). This will mean you can very easily circumvent/bypass the Park/Neutral start disable switch, and get everything running really easy!
    • If the roof is dual skinned the whole way, IE, there's a "top" metal piece, and a "bottom" metal piece, to slow it down as much as you practically can, you should be able to get an attachment for a spray can/your spray gun, where it is a long, thin flexible hose, and when you're "spraying" it is spraying it in every direction possible. The I'd get that, and feed it through the roof as much and as far as you can. It's basically like fish oiling the car, but you're soaking it in rust converter. Then do the fix like Murray has described having cleaned up the existing metal as much as you humanly can. I'd also throw as much rust converter on that exposed metal before putting the fibreglass/metal filler over everything.   As for welding a replacement in. I've owned my own MIG welder for about 10 years. I've also worked in an industry doing MIG welding for a job for about 3 months dead straight, and we were doing 11.5 hour work days 5 days a week, plus a Saturday 6 hour day. (I then moved over to running the massive CNC plasma as I could understand the technology, and work with the main guy out there). I also f**k around with my welders a bit at home. So what I'm saying here is, I've probably got more hours on a MIG gun than you'll manage to get under your sleeve doing home sorts of jobs over the next 5 years. I also have an ACDC TIG that I got myself a year or two back. I've got a short amount of experience on the TIG only. My home MIG is also presently setup for doing thin sheet metal. Unless I didn't care about how that roof looked, and I just wanted a functional metal roof, and it being out of alignment, warped, and bowed, I would NOT attempt a roof replacement UNLESS I could do it as a whole panel like Murray described where the spot welds were.  Welding has this REALLY annoying thing, where if you want something to be perfectly square, unless you can clamp that thing to damn perfection (Welding fixture table), it is NOT going to be square, so you start to learn, the type of metal you're working with, how thick it is etc, and weld in VERY specific ways, and by knowing how YOU are as a welder, so that as the welds cool, the metal work pulls itself into place. If you want to see some cool tricky shit done, Bennets Customs is an Aussie guy, and he mentions a guy a lot call "Kyle", who is from "Make It Kustom". Watch some of their welding videos, especially on sheet metal. You can use the welder to shrink the steel in, and you can also use the welder to stretch the panel out. When you have the skill level that I have, you can shrink the metal in and out... But never on purpose like those two guys do. You just manage to f**k it all up. Then I smack it around with a hammer till it sits lower than I will want it too, then I shove filler on top and then pray to deitys that I can sand it into some form of sane shape that doesn't look like a dog has taken a shit, after eating a tonne of pumice stone... I'm all for DIY, and for learning, and please, feel free to give it a go, but be aware, you need to live with the consequences of how time consuming it is to do, AND that it's going to look no where near as good as what you can make it look with just some filler now. Oh AND, even once you replace it, it's like to still rust away again eventually, because you'll have missed putting primer and paint on some part of the newly welded in sheet metal, or against part of the existing metal you couldn't get to...   Oh, and to weld all that in, you will need to pull the window out, and strip at least the roof and A Pillars of interior trim and wiring. You'll then need things like the big fire proof/weld spatter proof mats to lay down, OR you'll end up needing to strip the ENTIRE interior to avoid sending it all up in a ball of flames. If you want to see how annoying sheet metal is to weld, head to bunnings, buy there 600x600 1.6mm mild steel (Not GAL!) sheet, and cut a few pieces, and try and weld them together. Then understand, 1.6mm sheet is nearly 50 to 100% THICKER than the cars sheet metal.   The photos I posted before, I'm replacing with 1.2mm thick mild sheet, and it's very easy to blow through both the original steel (Especially if I hit an area that should have probably been cut out a bit more) or straight through the new sheet metal. And I'm doing the floor, which can be hidden easily, and doesn't matter how pretty I make it, as long as it's damn strong! I'm also doing it in a 4WD, that has seen many off road trails, and doesn't need to look that pretty ever
