R34 Gt-t Left (passenger Side) Window Glass Smashed..
Recently got my coupe R34 GT-T's left (passenger side) door window glass bashed.... :) Does anyone have or know where can I get a fast replacement (including installation preferred), in Sydney area? Any other suggestions welcome. Thank you!
Edited by m-p
Ask satanic (Stan). His car recently got broken into and I'm pretty sure he had to get a new window (not sure if it was passenger or drivers side).
Or better still, wait for someone who knows an asnwer to reply ^_^
Thanks guys for all the replies.. :( I have contacted Stan, he is very nice and informative.., but as he also got the passanger door's window broken. Therefore, I am still waiting to get the confirmation from some companies like Obriens, Novus, JustJap, SSS, and Nissan (Nissan did provide a solution but it is extremely expensive and lenghty). So any other suggestions will be really appreciated. Thanks once again, :laugh:
To Abo Bob: It is the door window..
Edited by satanic
I had my drivers side smashed when people tried to break into mine got it replaced by PowerPlay. They replaced it and everything for about 250 to 300 I think. Only place that had one for an R34. No point calling Obrians they dont have them.
Edited by CWest
$250 - $300 for a full window replacement + any associated trims is an absolute steal!
I had my mate run some prices from Nissan and the door window plus trims came to about $2k to repair!!!
I have PM'd Cwest to ask whether its the smaller glass or the door glass.. Because yesterday I received an email reply from SSS which said that they have the left window glass, for $250.... I gave them a ring to confirm that they have the door window glass, and again they said they have it. Finally I went to Girraween (near Blacktown) from City, only to know that they were mistaken, the one they have is the smaller one.... :laugh: At the moment, the best price I can get is from Randwick Nissan, $1190.35 excluding installation and 2 weeks delay....
Edited by m-p
See what I mean?
Also, $250.00 for the back quarter glass is a good price considering they are about $470.00 brand new (trade price) from Nissan.
Did you see if the rear glass came with the mould? Or was it just the glass... you need to get it with the mould, as it is a sealed unit.
See what I mean?
Unfortunately I didnt see the back quarter one they have as I dont need that part, so I cant tell whether or not it includes the mould..
Just thought I'd post up that my glass got re-fitted tonight... excellent job done by Mick from Unique Auto Glass! In and out of my workshop in about 1.5hours which included removal from another car and transfer into mine.
The finish is so good, you could swear I was never broken into :(
Also, for all those who think that the rear quarter glass cannot be transferred, you are wrong! Mick did it with a special tool and did it very quickly...
m-p if you need someone to do your glass, talk to Mick - 0425371057
Also you might want to call him up and talk to him about my case, then your case - apparently he's found tonnes of sources for the glass (topic of conversation tonight)
Might save yourself a dollar or two!
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
