No sorry guy's i can't provide a photo...due to one of our Cruiser girl's breaking the camera last week....
For those that have Skyline's if you can stick your head right under (if it's there) it will be bolted to the steel just down from the rear wheel....
ill try to locate a camera.....
Loz
ok i had a bit of a look under mine and im not sure if im looking at the same thing as you...ok but here goes
on mine i see this black i guess basket looking thing with vents in it....and it is bolted into the rear panel...as far as i can tell this is just a blastic cover to protect the things on the inside... as my car is different to most other r33's i have a resivor in the boot for my active diff. my plastic basket thing i would say is there to protect this and its contents eg such as the hose coming out and going to the diff and also there are a few other gizmos in there that may be related not sure??
Left or right side...... on the exhaust side...(LHS) There is a hose and vent thing on mine,i think that is for runoff of something...is there anything on the otherside..... That's where the one in question is
I thought it might be a secret compartment for something.... but it is exposed to the elements so that theory went out the window....
Prolly a vent into the bottom side of the boot. Have a look to see if it has a rubber flap deal, or, from the inside of your boot take the trims out (drivers side) and ferret down a bit and you should see the vent and inside of the basket thingo....if it is the thingo I am thinking you mean....
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
