hello!
im not sure what this is, but im guessing its some kinda bleed valve??? i dont have a clue really just asking coz my aftermarket boost gauge read 9psi....
its on a rb25det and its sitting on top of the AFM
im talking about the blue and gold thing
the second pic is large, 600kb or something. im guessing i can adjust the end of this with a screw driver, and i can run 12psi on the standard turbo safely???
Edited by Triskillion
https://www.sau.com.au/forums/topic/114223-what-is-this/
how do i adjust this??? either make more or less boost??
ps. i just tried turning the screw thingy insid and now ive tried afew settings... ive read between 6 and 0 psi.... how do i get it to 10?????????!!!!!
k ive done afew settings and tests. coz its raining i cant full throttle in first and second. even third spins a little. well in 3rd it goes to about 9psi. which is what it was on before i touched it. but i had a quick look in 2nd gear and only reachd about 6psi, and first was 0psi but if i full throttle in 1st ill just slide so i couldnt do that/
so what im asking is the reading in 3rd gear gonna be the same for the other gears??? if not am i gonna have to wait till it drys before i can test??
https://www.sau.com.au/forums/topic/114223-what-is-this/#findComment-2104806
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
