Turbo Timer - $30
No name boost controller with black hose (ready to install) - $10
Rb20 intercooler and some piping - $50
unifilter pod - $30
Rb20 injectors x6 - $15 each/$80 for 6
R32 rear sway bars! - $30 (good upgrade for NA s13's etc.)
R32 stock fuel pump - $40
R32 GTR fuel pump - $130 (currently still in car in perfect working order)
All parts are in Adelaide and would prefer local buyer but will post at buyers expense.
Have pictures of everything if you want them!
Edited by mr_rbman
intrested in dump
could i get pics to [email protected]
got a few ppl interested in the dump but if they don't come through i'll send pics!
Ash!
  • 4 weeks later...
Hey Mr rbman, i tried to pm you, but i dont think my PM system is working properly, anyways heres what i tried to send.
i'm after a rubber elbow which i think is from a rb20det. A mate from tafe gave this elbow that was almost 90degrees, but it had this big foam boot sort of thing around it with sections cut out. Anyways, i'm after another 1 of those cause the inside diameter is damn close to 60mm which is what i need. If you have 1, could you send a pic and what sort of price you might want. Send any pics to [email protected] Thanks
got your pm, don't have that, using it in my current setup!
what piping does the cooler have?
what bits are missing?
it has the piping that goes under the car, i am using the stuff that is seeable under the bonnet (stock look)
bleed valve is just a cheap one that a mate got with a VDO guage kit hence the price! I haven't used it but its brand new and never used!
Don't have a side clear indicator!
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
