hi guys ive taken the following parts off my r33 gts-t
* Top 1/2 of stock plenum and Throttle body- $90ono ( will seperate if both buyers are there)
* Assorted black and stainless steel piping, used with the hybrid cooler (pics on request to make things easier) $POA
* Oil Catch Can- no breather on top, return outlet to sump- $10
* Stock fuel pressure regulator- $20
* Stock washer bottle with motor -$10
* HKS pod filter ( filter needs replacing)- $10
* 3" dump pipe ( rusty) $10
* 3.5" dump pipe ( bit rusty but mainly good)- $20
* Support bar with bonnet latch (infront of radiator) $15
* Various hoses- $POA
* GFB Hybrid bov bottom attachment- $10
* Not sure what it is, but i heard it was a pollution thing, pic attached, GREEN- $POA
* Custom steel intake pipe with 4" attachment down to 3" to fit afm, or u can just cut the 4" piece off- $50
BOTH OFF TRUST TURBOS so they have a different flange, but u can just chop it and change the flange to bolt to stocker if u like
* center muffler from a 3.5" system- $15
* boot floor carpet and battery cover carpet- $10 each. or $15 for both pick up due to size and shape
* Splitfire coils series 2 rb25det SOLD!!!!
Available soon:
* sunvisors- $25/pair (33apx buyer)
* MAYBE: series 2 coil harness- $80
EOI: unsure yet whether to upgrade core size or not, but its a HYBRID (genuine bar and plate) 600x300x76- $350ono ( excellent condition!!!) handled 350rwkw with no problems at all
pics available for all parts
Cheers...Ben.
Edited by 2BNVS
https://www.sau.com.au/forums/topic/115493-lots-of-parts-for-sale/
dude - i want the battery cover carpet. Can you post it to me? If so, how much for postage?
i am in Melbourne. Please contact me at [email protected] .PM sent with my phone number
cheers!
ardie: i just got an autronic ignition system put on it, and needed series 1 coils that didnt have the inbuilt ignitor otherwise they would fry...
anexiole: pm sent
Pawley: ill have a lok for ya...
RBFIRE: ill give ya a pm later on regarding price
cheers...ben.
I will take the washer bottle, please pm me your bank details with how much postage to Sydney will be (another $10 should cover it?) and I will DD the money asap.
You seem to have left the washer bottle on the list, so I will offer to buy it again :wave: I can still DD the money immediately, but you can post it whenever is convenient for you.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
