http://www.skylinesaustralia.com/forums/in...opic=80624&st=0
HKS 2530:
TURBINE:
Inducer = 53.8 mm
Exducer = 47.0 mm
Trim = 76
A/R = 0.64
COMPRESSOR:
Trim = 63
Inducer = 47.7
Exducer = 60.1
A/R = 0.60
R34 N1's
TURBINE:
Inducer = 53.85 mm
Exducer = 42.4 mm
Trim = 62
A/R = 0.64
COMPRESSOR:
Trim = 55
Inducer = 44.57
Exducer = 60.1
A/R = 0.60
HKS GT-SS
TURBINE:
Inducer = 53.85 mm
Exducer = 42.4 mm
Trim = 62
A/R = 0.64
COMPRESSOR:
Trim = 56
Inducer = 44.46
Exducer = 59.41
A/R = 0.42
Edit: I have my suspicions that some of the A/R numbers are off. It looks to me for all the world like the R34 N1s were the base for the GT-SS, although someone else will have to comment as to whether they use the same catridge.
https://www.sau.com.au/forums/topic/115599-n1s-vs-2530s/#findComment-2130860
Hey No one
I recently bought a pair of Garrett GT2860R - 707160-5 and i'm happy. Lots of power on tap and very drivable.
My current RB is getting a bit long in the tooth for big boost and HP, but i'm still having lots of fun. Had some adjustable cam gears fitted as well as the usual bolt on mods
TURBINE:
Wheel dia. = 53.8 mm
Trim = 76
A/R = 0.64
COMPRESSOR:
Trim = 62
Inducer = 47.2
Exducer = 60.
A/R = 0.60
Edited by Mr. Keets
https://www.sau.com.au/forums/topic/115599-n1s-vs-2530s/#findComment-2131473
hey crimmo and mr keets
do you guys have any dyno sheets of them yet??
also whats the spool time like?
and cheers to Iwells for the link .... big help hey
Hey No one,
sorry i'm a million miles from my R at the mo, so i cant post the sheets. Check out turbobygarrett.com and you can see the maps, Mine is making 406hp at the back wheels, I picked up 70rwhp on a 17 year old engine...fuel system running out of puff now. Every combo is different and so is the tune up.
Find a good tuner and ask to see some dyno sheets.
https://www.sau.com.au/forums/topic/115599-n1s-vs-2530s/#findComment-2137605
From my research, it looks to me as Lucien suggested: That the R34N1 are more or less the same spec as the HKS GT-SS.
Now remembering that both of the above are based on a Garrett Turbo,
The version of Garrett GT2860r that I bought is the "-7", and I got this because it had more or less the same specs as the GT-SS.
I've recently gone back to the Garrett Website and now find that they have actually mentioned that these are indeed the "OEM on Nissan RB26DETT used in Skyline R34 GTR N-1..."
You can see it here:
http://www.turbobygarrett.com/turbobygarre...0R_707160_7.htm
Read the little blurb on the left...
...and yes - they are an excellent turbo I think.
https://www.sau.com.au/forums/topic/115599-n1s-vs-2530s/#findComment-2141261
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
