To run the RCAs from the front to the back all the skirting on the inside of the car unclips and lifts up. Now to get the RCAs from the back seat to the boot is a bit tricky, what you need is a unravled wire coat hanger or some wire. On the side of the seat pull it away from the edge of the door and stick the coat hanger/ wire through so it reaches the boot (it took me about an hour to achieve this so it may take a while) now make a loop in the wire and make sure that it is fairly tight around the RCAs and pull it through from the boot. It is not a quick task but is extremely dificult.
Now clip all the skirting back together and it should look like nothing is running under it.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2128030
I loosened the seat-bolts.. bum and back. Then lifted them up half a meter and just poked the RCA's through one of the little holes that go into the boot. There is already a wiring harness that runs up that way, so turn on and test the unit before you put the carpet, seats and stuff back in. Interference in the RCA's is a common problem in R33's it seems.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2130749
Cheers dudes, my mate sugested going under the centere console slicing a hole in the carpet on the tunnel feed in under the seat etc etc, but the trim on the sil seems the way to go, about the rca interferance wat would cause that..........i got earths on my rcas iwasnt going to earth them( my last intall i didnt, worked fine) but i might now.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2133525
Pulling the seats out and back takes less than 1/2 hour and allows you to tape/zip tie the Rca's. I ran mine down the transmission tunnel to the back seat, A fair bit harder, along te side would definatley be better.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2133650
There is a harness that runs up the side already, try to stick to that.
I removed the rail that holds the seatbelt on, as it was neater to go under that. Easy.
The door-sill pops off with a gentle tug.
Remove the kickpanel where the ECU is, one nut on the footwell, then there's just two clips holding the side in, tug it off.
There is a round section next to the passenger seat, under that moulded piece of carpet there is an upside down U shape, where the wires can run over very nicely. You can work out the rest, but those minor details may help.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2135158
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
