  • 4 weeks later...
Ok, forgot this part:
The goop that seals the light sticks like a mo fo. The best way I found to help get the light off is to get a hair dryer or heat gun to heat the inside metal panel that the light sits on. Be carefulwith a heat gn, you don't want todamage anything. Anyway, this should heat the goop up enough to soften and become more malluble. Start pulling light off as it heats.
That should sort it out!
You might need to drill holes in the bottom of your indicators.
After i sealed my lights, water was still filling my indicators and coming in through the bulb sockets.
The sealing was necessary in my case, coz there was a leak there aswell.
If you drill holes, make sure you take your bumber off first so you can get in under the lights. That way the holes wont be visible.
So far so good, my boot is still dry.
  • 4 months later...
