Yes I know it has been covered, but my questions weren't answered.
Does anyone local with Xenon headlights still run them?
I've got a set which will obviously be removed for compliance and am wondering whether they're worth keeping enough to switch the whole headlight units for factory halogen ones before compliance, or whether to just let the workshop modify them to halogens and not go to the trouble.
Obviously, if someone has factory halogen lights lying around, PM me.
https://www.sau.com.au/forums/topic/116471-r34-owners-in-sa/
Xenons aren't ADR approved.
The only reason European ones get them through is cause there are so many and they are self levelling, e'g' if ur car is driving up a hill they will lower.
The rules are shit but they are an unbelievable invention.
the more colour in the globe the less actual light from the globe, e.g. 5000k white lights up the most, and 10,000-12,000k purple least light.
I can do custom installs if need be, and they are only suitable for projecting through a lense as the light needs to be focused, so u need r31 lights or r33 gtr lights. Or u could go and get vx calais lights and modify them to your existing.
no all R34s don't have Xenons - mine doesn't.
I have installed an aftermarket HID kit in my R34, which i had in my S15/200SX. They worked brilliantly in my S15, had a nice cut-off line and all was good.
However, as WWWDOT pointed out, my standard R34 headlights are not projectors, so the HID light looks very bright from the front and there is no cut-off line. I am considering taking WWWDOT's advice and modifying my standard lights to include VX Calais projectors. I am very worried about getting defected for them, as even though I have pointed them way down at the road, they are still very bright from an oncoming car's perspective.
hay guys, I ran a HID light system on my race bike last year. I had a single HID set up on a 7'' hella. Was the best money ive spent. Hid's provide the best light, and the whiter the light the clearer everything seems. I Used the light in the 24 hour and all the other road trials and they are just amazing. I cant wait to get some for my car!
i heard that some places actually keep your 34 xenon headlights in exchange for the halogen ones when they do compliancing? correct me if im wrong
i was told best enterprises does this.. so some ppl might of had xenons in their cars but had them taken out without knowing??
who did you guys go through for compliance??
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
