Yes I know it has been covered, but my questions weren't answered.
Does anyone local with Xenon headlights still run them?
I've got a set which will obviously be removed for compliance and am wondering whether they're worth keeping enough to switch the whole headlight units for factory halogen ones before compliance, or whether to just let the workshop modify them to halogens and not go to the trouble.
Obviously, if someone has factory halogen lights lying around, PM me.
https://www.sau.com.au/forums/topic/116471-r34-owners-in-sa/
Xenons aren't ADR approved.
The only reason European ones get them through is cause there are so many and they are self levelling, e'g' if ur car is driving up a hill they will lower.
The rules are shit but they are an unbelievable invention.
the more colour in the globe the less actual light from the globe, e.g. 5000k white lights up the most, and 10,000-12,000k purple least light.
I can do custom installs if need be, and they are only suitable for projecting through a lense as the light needs to be focused, so u need r31 lights or r33 gtr lights. Or u could go and get vx calais lights and modify them to your existing.
no all R34s don't have Xenons - mine doesn't.
I have installed an aftermarket HID kit in my R34, which i had in my S15/200SX. They worked brilliantly in my S15, had a nice cut-off line and all was good.
However, as WWWDOT pointed out, my standard R34 headlights are not projectors, so the HID light looks very bright from the front and there is no cut-off line. I am considering taking WWWDOT's advice and modifying my standard lights to include VX Calais projectors. I am very worried about getting defected for them, as even though I have pointed them way down at the road, they are still very bright from an oncoming car's perspective.
hay guys, I ran a HID light system on my race bike last year. I had a single HID set up on a 7'' hella. Was the best money ive spent. Hid's provide the best light, and the whiter the light the clearer everything seems. I Used the light in the 24 hour and all the other road trials and they are just amazing. I cant wait to get some for my car!
i heard that some places actually keep your 34 xenon headlights in exchange for the halogen ones when they do compliancing? correct me if im wrong
i was told best enterprises does this.. so some ppl might of had xenons in their cars but had them taken out without knowing??
who did you guys go through for compliance??
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
